then your only using one coil , not bothi have it wired at 2 ohm right now, so should i just re wire it to 4 ohm then?
Using both of your coils is basically using your sub to it's full potential. Wiring to four ohms would reduce the power your amp will be able to send to your subwoofer, but at least then you'll be running it the way it was designed to operate.sorry i am new to DVC and subs, what would i get out of the using both coils? wiring it to 4 ohm?
