2 ohm or 4ohm
There generally won't be an audible difference in running an amp with a 2 Ohm load versus a 4 Ohm load. The only real difference will be at the lower impedence the amp will create a larger current demand on your charging system.
Yeah... just be sure your amp is stable at 2 ohms... cause mine is not. I wanted to put two subs on it and double the power of my amp so each of my subs would have the same ammount of power as my single receives now... but I can't //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif.
kngadrok
STW
kngadrok
Arlington, Tx
sTaLa
