2 independent subs?
Is there any way I can set up a sort of 2-channel system where I have one softer sq sub and amp for easy listening and soft folk and can with a switch or dial shut it off and change over to a big, pig of a SPL sub for orchestra and pipe organ music?
just get a SI Mag and be done with it. Great sounding with the ability to pound
x3 Remote gain knob is your friend. I keep mine dialed way back 99% of the time and let my mids do most of the work, but do have the option of cranking up the subs when in the mood for some killer kick drums or whatever.
The right subs/box should do what you need without having to do 2 separate subs/boxes...
"remote gain"; Is that like having an independent dial to ajust the base on your one sub channel? Because that's starting to make a lot more sense than toggling 2 seperate subs. I'm playing romantic period orchestra which requires both SQ and extreme SPL.
Get a pair of the 13.5 W7's they will do what you want
For less money you coudl go the SI mag route
a treo of IDMax would do it as well.
A 18" or 15" Fi Q might also do what you are asking.
Do you have tons of space?
What is your budget?
RMS on amps available for this install?
killdevil fox
killdevil fox
Pumkin Peak, Appalachia
killdevil fox
