Flex68
dilligaf
I am glassing two separate sealed enclosures for 12" subs. These are going in a confined space, under the rear seat of Dodge quad cab. This is a daily setup, with around 800WRMS planned for each sub, to start.
Due to the differences in the underseat wells, I am looking at the rear passenger side being at 1.1cubes, while the driver's side will offer 1.3cubes... about a 15% diff.
Since I am geared more towardsr SQ, I know that this is not a good thing.
Is it feasible to simply add polyfill to the smaller enclosure, or will I have to "short" the depth on the 1.3cuber to bring it down to 1.1 ?
How much luck you think I could expect if I try to EQ out the differences if I go with poly?
(Due to planned placement of my mono amp, glassing all the way across to achieve common chamber is not an option)
