(2) eD NINe.2x SQ amps
wew lad
wew lad inc
6,215
214
VA
Two NINe.2X two channel SQ amplifiers. High sound quality Class AB amplifiers, these things are heavy and rated at 12.5 volts!
I purchased these amplifiers locally from their original owner, he told me they were purchased back when eD was still around and when he became ill the amps went into storage. Up until recently he had forgotten about the equipment and then decided to sell it. Unfortunately I do not have the original boxes but they will be shipped well packaged by a carrier of your choice (within reason).
Amps are fully functional 10/10. They were bench tested with an oscope and a subwoofer.
Cosmetics are 9/10 due to the minor scratches on the amp in normal use locations, I can take extra pics if requested. No scratches on the beauty side of these amps. All set screws are present and function.
Detailed specs found here:https://web.archive.org/web/20060621153526/http://edesignaudio.com/product.php?cid=17&pid=33&tab=Specs&cur=USD
NINe.2X Amplifier Power Ratings
RMS Wattage Rated at 12.5 volts!
600 x 1 @ 4Ohm
200 x 2 @ 4Ohm
300 x 2 @ 2Ohm
NINe.2X Amplifier Detailed Specifications
Signal to Noise Ratio
-95dBA
Variable Input Sensitivity
150 mVolt - 7.0V
Remote Variable Input Sensitivity
Yes
Variable Low Pass X-Over
40-240 @ 12dB
Current & Thermal Protection
Yes
Remote Bass Equalization
No
Variable Phase Control
Yes
Master / Slave Option
No
Efficiency
Variable SubSonic Filter
N/A
Fuse(s)
2 x 40
Max Current Draw
85
NINe.2X Amplifier Size
Length
14.70
Width
9.85
Height
2.25
$170 for one amp shipped
$300 for both shipped
Give me a shipping label or pick it up locally for OBO
see above
check out the eD subs I have for sale! http://www.caraudio.com/forums/subwoofer-classifieds/618725-ed-minty-13ov2-16ov2.html
I was fortunate enough to have a trusted member on here offer to middleman for me in case the buyer is unsure due to my low amount of feedback. I've worked with multiple people on this forum, but if you want to have this item middle manned I am willing, PM me for details.
These amps will ship from 32114 by the way, or can be picked up locally.
topside for some great sound quality amps
pair it with one of my eD subs for sale and you'll have a great set up
boxed up and ready to go folks, had a buyer but i jumped the gun on an offer and shipping ended up being too much for the deal to work
[/img]
bump
150 each or trades for a 80prs, and beefy SQL 12s or a 15 +- cash depending on value, offer up!
If we are allowed to testify about these amps, I will. I've been running a 9.2x for 4 years now for my mids and highs. I've listened to a lot of 2 channels, and this amp provides clean wattage comparatively. This amp is powerful. I know the 9.1 series amps are underrated, I've owned 2 9.1's, a 9.2 and I suspect the 9.2x is underrated as well.
If I wasnt unloading several amps myself, Id pick these up to go along on sub stage while utilizing my 9-5 on the entire front stage.GREAT AMPS!!! GLWS SIR!!
439
566
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
wew lad
wew lad inc
wew lad
VA
wew lad
