2 DSS ethos 15s D2
atoz2
2 DSS ethos 15s D2
One is BNIB only opened to take pics, the other was used for about 2 months has some wear from mounting. The BNIB has direct leads, where as the other has push terminals. I have all original packaging for the new one
Specs:
The Ethos, was designed with two goals in mind. Tight articulate bass and the ability to work in small vented enclosures.
A stiff high pressure kraft fiber reinforced cone with a multi-layer foam surround is used to accommodate the 32.5mm of one way xmax. To handle the 2,000 watts of recommended power necessary to push the cone to xmax a rugged USA made3 inch 4 layer flat aluminum wire coil wrapped on a black anodized aluminum former is used. To ensure music is tight and articulate four eight inch true progressive spiders are utilized along with a FEA optimized 50 pound motor structure. All production samples are tested with a Klippel analyzer to verify parameters and ensure product performs as designed.
FEATURES
2,000 WATT RMS RATED
TRIPPLE STACK 8.6 INCH OD MOTOR STRUCTURE WITH BLACK CHROME FINISH
FOUR PROGRESSIVE SPIDERS WITH WOVEN TENSIL LEADS
STANDARD UPGRADED DIRECT LEADS WITH XS POWER TRUE 8 GAUGE OFC CABLE
HIGH PRESSURE KRAFT FIBER REINFORCED CONE
MULTILAYER FOAM SURROUND
WRAP AROUND RUBBER GASKET
USA MADE 3 INCH 4 LAYER FLAT ALUMINUM COIL ON BLACK ANADIZED ALUMINUM FORMER
DUAL 1 OR 2 NOMINAL IMPEDANCE VOICE COILS
SATIN BLACK CAST ALUMINUM BASKET
T/S PARAMETERS
Re3 ohms
Le2.94 mH
Qms10.6
Qes.69
Qts.64
Fs25.78 hz
Mms362.9g
Cms.1 mm/n
BL21.43 t/m
Vas95.9 l
SPL88.22 1w/1m
Xmax32.5 mm
Power2,000 Watts
NOTE: All parameters were extrapolated via a Klippel analyzer using LPM and LSI measurements. The recommended power rating is not a max input power rating. It is the necessary power needed to drive the subwoofer to 32.5mm xmax in a ported enclosure 3 cubic feet tuned to 32 hertz. This rating will vary depending on enclosure size and tuning.
Klippel results extrapolated from production samples and may vary without notice. Klippel testing was performed by Redrock Acoustics.
ENCLOSURE RECOMMENDATIONS
Sealed:ported
Volume: 3.4ft^3Volume: 3.0ft^3
System: Q .9Tuning: 32 hz
Port Area: 75in^2
Ripple: 5 db
F3: 28 hz
NOTE: All volumes are net and do not include port or subwoofer displacement. Enclosures are recommendations only and can be adjusted per the customer’s desired system response. Recommended enclosures do not consider transfer function
PHYSICAL DIMENSIONS
Outer Diameter:15.625"
Cut Out:14.125"
Mounting Depth:9.250"
Displacement:.24ft^3
NOTE: Leave .5 inches between rear of motor and enclosure for ventilation.
300 for the new one
250 for the slightly used one
Will do a deal if you buy both
Will work out with buyer
I can get better pictures if you need them just pm me
atoz2
atoz2
Hamilton, MT
merdoksparxx
