2 dd 9515g subs
I'd say like 2500-3k daily as long as ur not clipping it and in the right enclosure... I used to throw 2500 daily to a 9512f and it took it like a champ, so I'm guessing the G series could take similar/more power daily also.
thanks guys for the info im going to put a d9 on them tonight see how they react and if needed ill put the z2lv on them to make them hurt lol
To be honest, I'd like to see both 9515s powered by the z2lv. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I'm sure they will take it though. Those DD are very under rated.
With my friends two 9515's G's on 1600w each with a little clipped signal they start to smell a little. Once we get the alternator in and get more clean power they'll probably hold 2000w each before they start to smell. So I'm going with no more then 2000w rms for music. As for spl burps around 3000-4000 due to the paper cone. You'll tear the cone before you burn the coil for burps. Same coil with a kevlar cone I've given 6500w but from 4000-6700w on a 60hz note there was only 1db gain. So at subs limit.
Pay a couple more bucks and get the aluminum coil to handle more power.
RAB
RAB
georgetown, tx
dtbrown
