2 channel amp for a Alpine SWR-12D4
  • 2
topeteontop
I have pretty much zero knowledge on car audio and don't want to mess up my sub or amp and i wanted to know how i could run a dual coil alpine type R sub off of an old school 2 channel power logic 460 watt amp its 4 ohm , i wanted to bridge it to get more power out of the amp . if anyone could explain to me the best way to wire this amp ?
i realize this amp is no where near enough power for my sub but its only temporary
With that amp you can only either bridge the amp sub wired to 8 ohms. Or you can use 1 channel and wire the sub at 2 ohms. Depending on the amps power you could bridge it and only use 1 voicecoil of the sub. That's kind of considered taboo on this forum but can be done
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
462
511
10
896
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
918
topeteontop
topeteontop
corona,ca
garychoffmann
