2 amps
Fender5
I finally have two amps runnin. I'm using a power/ground distributer block.
4 gauge all around. 4 gauge as main, and 4 gauge to each amp. and 4 gauge ground
There was heavy there was some heavy interference but i fixed it after i moved the speaker wires away from the power wire.
The subs are weak for soem reason, and the front speakers do not work. The front ones are connected to the head unit right now becuase I am waitin on my components. Only the rear is powered by the amp.
Head unit only has 2 RCA outputs. Front & Rear
Im runnin the mono amp off the output of the 4 channel. It worked better
What could be the cause for the weak bass and front speakers not working
im assumin so. i need to redo it tomorrow. i spent roughly 8 hours getting it to work. stripping, crimping, cutting. redid my mono amp wires.
had a hard time gettin 4 gauge into the 4 channel amp even though it says 4 gauge recommended.
i'll make sure i check that.
the 6X9s came alive man! Never amplified speakers before. I can't wait to amplify my components when they come in. They actually rattled the trunk. Just barely
Now why don't my front speakers work? I disconnected the front RCA that i had going to it and still no luck
speaker says 80W RMS. but the amp is puttin out 75.
The front speakers do work. I faded it to the front, the rear is just so much louder.
Now the subs are not working. I can hear them, but they are weak and sound muddy. I've swtiched the outputs around. and everything
I did output of 4 channel to output of mono
output of 4 channel to input of mono
output of mono to output of 4 channel
wat is the correct one
just plugging and testing like that could result in amp failure. if the output of the 4 channel is a full range out put that would go into the input of the mono. then you would have to check the xover settings on the mono amp. does the 4 channel have an option where you can run all 4 channels with just 2 rca inputs? also check your gain setting on the front channels.
Fender5
Fender5
Arkansas
Fender5
