2 amps vs 1 amp
It will be pretty close maybe, if its the same maker.Using 2amps,1- on each sub will prob run alot cooler also,verses a single amp,unless it has a built in fan.IMO:D
Under normal circumstances, a single amp (assuming similar efficiency numbers and curves) will almost always be more efficient than two amps. Less loss through wiring, less loss through internal components, etc. not to mention it would be cheaper and simpler to install. No real benefit to having 2 amplifiers.
Jimmy79
Jimmy79
Owens Cross Roads, AL.
mylows10
vegang
vegang
