2 amps to 1 sub?
You can hook 2 amps to a sub if it has 2 voice coils. The problem is getting the gains set exactly equal and they'd have to be the same power. I wouldn't even try it unless the amps were identical and you can set the gains with a scope.
I don't understand your 2nd question.
thanks, I will hook up 1 amp to each sub, luckily I had an extra sub I found, I was asking if I could split my RCA pre-amp outputs so I have a set to each amp, I think that will be possible? It is 2.2V output will 1.1V Im guessing? be enuff for the amps or should I do line level inputs?
new2one
new2one
Florida
DaBaller504
