2 amps, one sub
I suppose you ~could~ use 2 amps to power a dual voice coil sub, one amp per VC, but they'd have to be exactly the same with exactly the same gains and probably not practical. As far as bridging 2 amps... no.
also just a little info....the max figure on a sub or amp doesnt matter the only figure that matters is the rms....thats how much the speaker or amp can put out or handle constantly the max if for a brief musical burst....
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
It's fine to mount to the box. A lot of show car SPL setups have amps or other electronics mounted directly to the wood frame of the box or on an...
21
387
bumpinthanite
i like cars. a lot.
bumpinthanite
the hills of Michigan
MikeofTulsa
