2 Amps For One
dross93ranger
I have two amps I would like to trade for 1 amp. It needs to be small (12x12" or smaller) and I need to be able to push atleast 500W RMS at 4 Ohm. I would hate to get rid of the 6104d since it is currently installed and I love the small size of this amp. The KAC-8401 I have never had installed, I traded Joseph 7195 for it a week or two ago and it is in great shape. If I wasn't broke right now I would keep them both since I have uses for both. Below are the specs and pictures of the amps. I do not want to disassemble them so please don't ask for gut shots. Post up what you have! I also have a 12" Polk Audio D4 DXI Sub.
Both shows signs of normal wear and few small marks, but nothing major. These are great little amps.
Kenwood KAC-8401
Performance
RMS Power Output (Watts x Channels) 60 x 4
Peak Power Output (Watts x Channels) 320 x 2
Power at 2 Ohms (Watts x Channels) 90 x 4
Bridged Power (Watts x Channels) 180 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Best Frequency Response 5-50k Hz
THD at Rated RMS Power 0.08%
Signal to Noise Ratio 100 dB
Input Voltage 14.4v
Features
Amplifier Class AB
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 50-200 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0/6 dB
Bass Boost Frequency 90 Hz
Fan Cooled Yes
Fuse Rating 40 x 1
Speaker Level Inputs Harness
Preamp Outputs 1 pair
LED Power Indicator Yes
Width (inches) 12-1/2
Height (inches) 2-3/16
Depth (inches) 11-1/4
Kenwood KAC-6401D
Performance
RMS Power Output (Watts x Channels) 200 x 1
Peak Power Output (Watts x Channels) 600 x 1
Power at 2 Ohms (Watts x Channels) 300 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Best Frequency Response 20-200 Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 75 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Slope (dB/octave) 12 dB/oct
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost No
Bass Boost Frequency N/A
Fan Cooled No
Fuse Rating 30 x 1
Preamp Outputs No
Width (inches) 7-7/8
Height (inches) 2-3/8
Depth (inches) 9-1/8
dross93ranger
dross93ranger
Maysville, KY
dross93ranger
vegang
vegang
