2 Alpine Type X 10's or 1 15" L7???
KTFO
MMworld
I have 2 Alpine Type X 10's currently in 3.2^ @ 36hz....a local guy has a BNIB 2008 L7 15" he wants to trade me (he's also throwing in $50). I am running the 2 Alpines on my Brutus 2008d @ 1 ohm....would the L7 be louder on the same amp? Which has more cone area? Someone help me out here...
I would but he has it in a 2.8^ prefab ported, my experience with L7 15s is that they don't really come to life unless you have around 4.5^.... so to audition it in my car would be useless I think. My Type Xs are loud as ****...
Where are people coming up with these vs. threads? You do realize that those subs would almost NEVER be bought by the same person? The Type X is one of the best SQ subwoofers money can buy, and the L7 is a pure SPL subwoofer.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif :uhoh: //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif That's close to HALF of what that speaker should be in. Throw it in 4.75 cubic feet and then it'll start to wake up.
I can answer the cone area question.
Area = pi x radius squared
Area of your two 10's = 157.1 square inches
Area of one 15 = 176.7 square inches
Did you just use the formula of finding the area of a circle, on a square object?
Yep, I think you did, moron.
Although, this would be relevant if the L7 was circular in shape, but it's not.
well what is the cone area difference then? I think the 2 type x's may be louder because they have more xmax but a little less cone area.... isnt it some thing like sd X xmax = Vd?
OK, so the L7 is even more bigger than his two 10's.
Yep, that's right, I said more bigger.
Edit: In fact, 15" x 15" = 225 square inches, which is 43.2% square inches more area than two 10's.
The formula for a flat circle at that. The actual formula for a cone is different.
I asked about that in another thread, can't remember which one now, but the posters there said the opposite of that. I'll look for it ...
(Edit 1: Actually, I should say, yes, I know the surface area of a cone is a different formula than for a flat circle; The posters in the other thread said you do not consider the conical aspect when comparing woofer areas. Not that it really matters to me, but I'll see if I can find it ...)
Edit 2: Here are the posts by audioholic:
http://www.caraudio.com/forum/showpost.php?p=6577060&postcount=20
http://www.caraudio.com/forum/showpost.php?p=6577353&postcount=23
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
651
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I would just go with a ported box tuned from 32 hz. - 35 hz.
KTFO
KTFO
MMworld
KTFO
    May 24, 2024
    May 23, 2024
