While I was setting my amp gains using the DMM method. I measured both the left and right channels, and I noticed about 2-4v difference between each channel.. Is this normal? If it is, should you set it to the channel that's measuring the most?
if its 12.7 to one channel, and 14.1 to the other channel, thats a 10 watt difference, assuming 4 ohms that is... 50watts to one speaker, 40watts to the other...I'll have to check again tonight and write down the actual voltage difference accross the channels. I think it was around 2v. I've a feeling it maybe the HU.
I can defenitely tell because my stage is moreso towards the passenger side. If that's the case do you know of any workarounds? i.e. balance a little more to the weaker side for a temp solution?
