2/3 ohm stable amp?
2jz
Hello, guys I'm new to the board, just would like some suggestions. I'm looking for a good budget amp that can handle a .67 ohm initial load. I have 3 powerbase 15's that are dual 4 ohm and rated at like 400 rms. I know that the impedance will rise, I've built a 6.3 cube box for them ported. I guess after rise the load will be around 1.5-2 ohms. What's my best option if I want around 12-1500 watts, would one of the ap amps be a good fit?
Hey thanks for the reply, but do you have any other suggestions? I was going to run two amps on them but now I want to do one. I was going to run them at 2.66 after looking I see that I won't be using the amps full capabilities. I'm not competing or planning to upgrade so I think the sundown is out of my price range. I haven't been keeping up with audio, is .67 still too low for a daily amp?
its too low for a lot of the cheaper amps. They'll most likely run it, but for how long is unknown. What is your price range? Theres a broken 1500 for sale here, send it to db-r to have him fix it...
Yea, that's what I was thinking but I know that I'll need a good bit of overhead. I was looking for a 2000 watt 2 ohm amp. But I can't find a lot of class d ones. I know that sundown is good but I not in the position to buy right now. So I looking for something I can get on ebay or something at any time.
The opti 2000 looks like a good suggestion. I originally was going to run 2 lanzar 1200 d's on them, but couldn't find a 2nd one.
2jz
2jz
Covina
I Like Waffle
