ok i have pics (have to try and find the usb cord because someone looses it everytime i try to use it)...but anyways
i finished the box...put the subs in, set the gains, and took a listen and........................................................................
THE FUCKING AMP GOES INTO PROTECT!!!!!
the amp is wired to 1 ohm (i know fi says the coils are .7 ohms for the bl's but mine were 1 ohm all the way around). i am set up to max out @ volume 65. i can turn my volume up to about 60 (depending on song, some will only go to 59 or so) and the amp will go into protect, then quickly go normal then back to protect until i turn it down to under 60.
my first instinct was "low voltage". so i used the multimeter but voltage stays up pretty good, and watching my analog gauge sometimes the amp would go into protect after teh voltage drop, and other times it would just go into protect once i went to about 61 or so in the volume, even with no voltage drops.
then i made sure my subs were wired to 1 ohm...and they are. checked ground, rcas, power, remote turn on, and i cannot play the amp any higher without it going into protect. anyone have an idea what the hell is going on?
the only possibility left is that my preamp voltage is too high. i have 8v preouts and the kicker is rated to take 5v in. but at volume 65 i dont think my HU puts out higher than a 5v signal.
so many things have been going wrong on this install. murphys mother****ing law
videos are not even worth while since i cant max it out, but i do have pics and as soon as i get the cable ill post them up.
