2 15s or 3 12s
So far I just have dual alts, 5 deka group 31s and all sky high 1/0 wire. I might end up doing 3 12" Dual 2ohm HDD's on 2 powerbass 5ks strapped at a little under 2 ohms.
So how about the 3 12" HDDs on around 10000rms or 2 15" SHDs on around 10000rms??
Cone area is too close to make any difference. The 12's do have more power handling capacity, but watt for watt the systems will be close probably the first several thousand watts. If your only doing 10k, I'd save myself the price of the extra sub and do the 2 15's. Output should be impressive either way I'd imagine.
x2. The 15s have just a -bit- more cone area; nothing that'll make a difference, but they'll definitely be able to keep up with the 12s. This way, you'll be able to provide more power/driver while keeping your draw significantly lower. You'd also be saving by not having to buy a 3rd driver, so I think the dual 15 setup would be all-around the better way to go.
Four tens? man that wasnt one of the options... lulz
I vote for whichever combination has the smallest combined Vas. Over-sized blowthroughs work out better than stuffed
I know lol.... I cant make up my mind. I already have the amps and camper shell. I just need to decide how im going to do the box set up and get the subs. I am currently running 4 DD2510s. So I figured I could build the box for 4 10s and run the DDs in it till I got the tantrics. Plus the 4 tantric hdds would take the 10k perfectly
Dub7sonoma
Premium Member
Premium Member
Dub7sonoma
Greenwood, La
Dub7sonoma
