2 15 Type Rs + AB 500.1(.5ohm) = *VIDZ*
you bringing the 4 12's to SBN?
how do you like those amps?
i am thinking about getting either 4 400.1 or 2 500.1's
Nahhh....too far and i havent gotten the box yet or run wire and install alt
I like it...at .5 ohm(granted i have garbage elec) it only drops to like low 12s at prolly 4/5 tilt...than full tilt with stock alt and 4ga run itll touch 10.9 if the batts havent been charged, but never gets warmer than the outside temp:D
The 500.1 is supposed to be the end all be all compared to the 400.1.....more watts with less draw is what Bob has said
i wish i could still do this with my four 12's
ur box is at ur house.. get ur *** home
Yesss it is...sitting in my kitchen..and i wasnt home ha
Mannn 155 legal....hope im close to that when its all said an done
I might hookup 4 subs to one amp for a bit.....ORRRRR.......take backseat out and run the wire and all Sun than hook everything up next week:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
Mann...also...46hz...that had to be sick to daily......ill be trying for it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
as long as your installing everything i thought i would show you this. just came up with the idea like 5 min ago. so with explorer's you cannot go from running the car to car ignition without reseting the deck. on my deck also if its paused and then gets turned off and on again it gets unpaused which gets annoying. another thing is the car itself takes a small amount of current on the ignition. so i thought to bypass that you can just wire something up like this. i dont know if you would be interested in it but for db drag it will help me a lot. before sbn i will put this in.
Skip01
Diggy
Skip01
Marrero,LA
PSturmer
