2 15" davinci's in my golf
idontwant1
hey guys i need a bit of help ..here goes
i just baught 2 15" soundstream davinci's stream sya optimal box would be 1.5 cube box with a 4"x12" port ... per sub
now i was thinking a box with 2 chambers each chamber bmountedeing 17x17x10.5 approx 1.78 without the port or sub mounted ...what do you guys think i can stretch the 10 to what ever number to make this work better .. also what size slot port would be needed ...im leaving it with you guys now
thanks havoc heres the rephrase
i hav 2 soundstream davinci 15"s the onoly info that i have to build a box is each sub needs a 1.5 cube box with a 4"x12" port
so heres what i want to build a box that has 2 chambers each measureing 17"x17"x10.5" internally approxamatly 1.78 cubic for each sub now will the sub basket and port bring me down lower than 1.5 cubic foot or shouldl i be ok and how would i convert a 4x12" round port to a slot port
thanks alot for the help
would the port still be 12"deep and i might be amping the subs seperatly in the end so i figured dual chambers might work better but i like the simplicity of a single chamber with 1 port
ok this is what you do. Find the displacement of the sub. This is how much air space the sub takes up. Add that to 1.5, and you should see how big to build your box. If you dont want to do that, somewhere around 2 cubes before port and sub displacemt should be ok. To find out what a 4 inch port comes to in sq inches, you do Pi*Radius Squared which is about 12.5 sq inches. You can build the square port that is 12.5 sq inches to be the same as a 4 inch opening. Personally i would do a bigger port, something around 30 sq inches to make it sound better.
And if you are using 1 amp, use a single chamber, and just make two ports. a single chamber makes it easier to ensure the subs have the exact same air space
My dad has oneand we are sending it off to have the internals switched with modern equivalents as well as cosmetically refurbished. I want to...
Quitter! I triggered you and I wasn't even talking to you. You're weak kid. You came at the wrong person. Blocking me is a sign of respect IMO...
92
6K
idontwant1
idontwant1
the megacity
ruxpin20
    May 31, 2024
    May 24, 2024
