Alpine4life 10+ year member
the 15XXX would cost me 460 and the two 12 inch L7s would cost me 420...which should i get if im lookin for the best spl?
I would go with the L7 12's if room is not an issue. Get a ported box with like 3cuft a chamber and run about 700-1000watts a piece. They should hit anywhere from 145-155db.I am actually going to buy a XXX 15" but I have a small sedan with not enough room for 2 12's ported. I'm probably gonna run it off a Audiobahn A1500HCT (2000w@1ohm) and put it in a 4cuft ported box.. that should hit mid to high 140's.
bah...i still want to know why it matters what he chooses,as i looked into his other threads it appears as if he doesnt already have the sub.Why are u asking this? seems like u have a XXX already...
you just repeated exactly what he said...exactly.You already have the XXX,why does it matter?
It can take more than that with no problems daily //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifThe l7's would take about 1kw at the most each,and the XXX would take 2kw at the most each.
dude i said it could take 2kw silly.Was that 4kw daily?seen a pair of kicker l7 8s take 4000 rms from a zapco 4kw....took em fine and i know the xxx can take 2kw
i know someone who gives each l7 2.5kw daily,but he knows what he is doing.Not to say Alpine doesnt...but i wouldnt recommend it.and I bet the XXX can take more than 2kw daily but if you know what you are doing.I know chris's 18XXX will get 2kw daily.It can take more than that with no problems daily //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you said 1000w not 2000w like i just said.The l7's would take about 1kw at the most each,
i said that because i know a guy with a 12l7 and 1.2kw and he blew his sub after 2 weeks,this one shop set his gains and everything and i looked at them and they werent high at all,and the guy didnt know much about it,so i figured to say 1kw daily would be fine.you said 1000w not 2000w like i just said.
