2 12" Alpine Type-R's and a Fosgate BD1500.1
evilsaint
I have 2 12" Alpine Type-R 4Ohm DVC subs and a Fosgate BD1500.1 amp. I have no problem hooking up the subs into a 4Ohm load, but I can't figure a way in hell of wiring them into a 2 Ohm load. Any help would be appreciated, because considering the relative simplicity of the question, I really feel like a dipsh!t not being able to figure out how to do it. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
How would I go about wiring the subs into a 1ohm load? My amp was modified to run at 1Ohm stable because it's former owner used it in SPL competition. The subs might not be able to handle it, but I could always buy two more.
To get a 1 ohm load you just wire all the positive+ inputs together and all the negative- inputs together. The impedance (ohms) of the speaker doesn't change, a 4ohm coil will always be 4 ohms, it's just how you wire them together that determines what ohm-load your amplifier "sees". Your subs have 2 4ohm coils each so when you wire all 4 coils in a "parallel" configuration( all +to+ and all -to-) your amp sees a 1 ohm load.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Because the amp has been modified to exceed the man. specs. In other words it's considered cheating. I have been at an IASCA event were someone had done the same thing. The 2nd place winner protested this and I watched as they tore the winners blazer apart only to find his amps were modified. Needless to say he went home empty handed and with a blazer full of parts to be reinstalled.
481
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
696
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
evilsaint
evilsaint
NW Chicago 'Burbs
Jasontb2000
    Jun 1, 2024
    May 31, 2024
