1ohm Stable A/B amps
I'm mainly wondering if there would be an audible difference wiring in series(16ohm) vs. parallel(1ohm) vs series/parallel(4ohm). I know motor strength vaies going from one to the other, but I just don't know if it'd make a difference or not.
"A higher impedance means more efficiency." Bullshit. It totally depends on what the amp is design for, there is no rule or law that says that a higher impedance is more efficient.
Though, lower impedance designs generally require more of the beefier parts, due to the amount of current the parts must handle as a whole. IE Larger SMPS transformers(More parallel runs of magnet wire compared to more turns), beefier output bridges to handle the current demanded from the low impedance load presented upon the SMPS. There comes a point where more current is desired over more voltage, given it is within part specs.
I believe they were talking about the drivers themselves being more efficient.
Oh. Still debatable-ish.
I personally like to use 8 layer quad VCs, in order to get that BL. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Though with more inductance you have a higher impedance rise when interacting with the fixed magnetic field... I think. If I remember that part of E&M correctly. Not my specialty.
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
MakeshiftAudio
Mike Mccabe
