1999 Camaro install, 6.5" drivers. Need advice.
ultimate157
Engineering Student
I'm trying to setup a system for my friend. He has a 1999 Camaro SS which he wants to use as a street/drag car, so weight is an issue. The car comes with 6.5" woofers on either side in the rear. I would have to trim the panel and build a grill over it to allow for the excursion of most after market woofers.
His thought is to re-use the stock locations with the Tang Band 6.5s I showed him. (Someone on here showed a video with 4 of them in a box ported)
He is concerned mostly with SQ.
How do the TB's sound? Would they work well mounted in the stock location ? Any other small profile woofers you would like to suggest would be great.
To compliment these I would put in a nice set of amplified components in the front , and a nice HU.
Price isn't an issue as far as the woofers go.
Hard to say from the description but if it's freeair you are probably gonna have a difficult time getting alot of subwoofer sound out of just a couple of 6.5's...
Id suggest 1 good 8, like a DD1008 or one of those RL8i's or maybe an 8W7 in a small ported box.
It might be wise to know how much bass he is expecting... If he just want's "more" bass from a stock location, what you said might work.
I've done quite a bit with f-bodies //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
With a little tweaking you can get the eD-700 to fit, which is their little 6.5" subwoofer and supposed to put out a little bit of bass.
You can also get a shallow 8 and put it in that panel as well. It takes a little work for that, but not too much. PM me if you want more info.
Every 100#'s will usually cost 1mph and a .10 in the 1/4, depending upon how fast the car is. Probably why I laugh when guys mention being concerned about saving a few pounds when installing a stereo.
Spray the world at that pig and you'll get that .10 back and then some //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ultimate157
Engineering Student
ultimate157
Worcester, ma
mlstrass
