1993 Chevy Silverado 1500 Build
IM1THE2KING3
Hello,
I'm new here so please inform me if at any point i'm doing something that is against forum rules.
The Basics:
Vehicle- 1993 Chevy Silverado 1500
General- This will not be an epic world record build in any way.
I am a senior in Mechanical Engineering so both time and money is limited.
I try to do the best with what resources I have and can afford.
On the side I have installed numerous sound systems for fellow university students.
Majority of it being prefab that people simply have me install.
I have also built a number of custom sealed boxes, and a small handful of ported ones for people to use.
I have fiber glassed once and I learned the hard way through trial and error.
This is my first aero/circular port build.
I have too many hobbies and not enough time or money.
I appreciate all feedback positive or negative as long as it is indeed feedback with suggestions and not just slandering.
I WILL BE ASKING LOTS OF QUESTIONS AND SEEKING ADVICE!
Gear- I understand I could have done better with some used things, but the majority of products used are all things I had laying around or left over from other people changing thr minds.
Headunit-
Alpine 9886
Amps-
Soundstream 120.4 Granite (old school)
Soundstream Tarantula TX1.2000D
Wanting a second Soundstream Tarantula TX1.2000D
Speakers-
Front: Polk db461 -scratched due to mounting depth
Front: Infinity reference 4x6 6422cfp
Rear: MB Quart 6.5
Subs-
TWO 15" Subs NEW that are cheap subs and I got them even cheaper, its a start...
Specs are as follows:
Fs(Hz): 23.4
Qms: 6.589
Vas(ft3): 5.451
Xmax(mm): 15.3
Xmech(mm): 22.95
Qes: .84
Re(ohm): 4
Voice Coil: Dual 2ohm
V.C. Diameter(in): 2.5
Rms: 1200
Max: 2800
Qts: .745
1w/1m SPL(db): 85.6
Overall Diameter(in): 15.75
Overall Height(in): 9.375
Mounting depth(in): 8.5
Wire-
Currently running one line true 4 gauge, looking to run 0 gauge to distribution or second battery (if needed or money allows) ANY SUGGESTIONS
Battery-
OPEN TO SUGGESTIONS
ALT-
Suggestions
BIG 3-
Wiring done
Box Dimensions-
Two separate boxes.
Width: 21.25
Depth: 17.5
Height: 16.75
V: 2.57477ft^3
4" aero ports I forgot the exact length apprx. 7"
Tuning to 35Hz
I will post lots of pics!
Due to time constraints I will devote saturday evenings to the build and try to get updates that night, currently I have spent a few hours over two weekends on the build.
Pics Products:
Wire-
Knukonceptz KCA 1/0
Knukonceptz distribution block 2 (0 Gauge) to 3 (4/8 Gauge)
Battery-
Tsunami Side Post long adapters
Anyone know of a kit for dual battery in the engine bay on my truck, i know specific models offered it but can't find anything when doing a quick google search.
IM1THE2KING3
IM1THE2KING3
Wichita Falls, TX
oxsign
