Sold 18" Kove armageddon U2
financethis
2500 RMS
4 " COIL
4000 Watts / Dual Voice Coil3
4 INCH XMAX
Carbon Woven or Polycarbon Stitched Cones for Accurate Excursion Control
Oversized High-Temp Kapton Voice Coils with 750 Degrees of Heat Disapation
Massive Motor Structure
Super Strong Dual Woven Spider Suspension
High Density Barium Ferrite Magnet
Strong, Pliable Cone Surrounds for Extended XMAX Control and Improved Tear Resistance
Custom Magnet Protection Eliminates Damage to the Motor Structure
UV Treated Woven Carbon or Poly Cones Reduce Distortion and Provides Superior Damping
Precise Fitting Gasket Insures a Tight Seal in Your Installation
Heavy Duty Speaker Leads Improves Flex and Accuracy
Vented Pole Piece on Most Models Keeps the Voice Coil Running Cool During High Power Operation
Inverted Dust Cap Design Provides Smother Musical Accuracy
NO TRADES. I TOOK THIS ON A TRADE.
NEED CASH
400.00 SHIPPED LOWER 48 ONLY.
OR PICK UP IN KANSAS CITY, MO FOR $340.00
Here ya go, these are from my BNIB, 1 hour sine wave break in 25Hz @ Xmax,
Re = 3.7306 ohms
Fs = 25.5016 Hz
Zmax = 39.6920 ohms
Qes = 0.4619
Qms = 4.4526
Qts = 0.4185
Le = 3.0806 mH (at 1 kHz)
Diam = 374.6500 mm ( 14.7500 in )
Sd =110240.5488 mm^2(170.8732 in^2)
Vas = 118.4972 L ( 4.1847 ft^3)
BL = 27.0991 N/A
Mms = 567.4714 g
Cms = 68.6374 uM/N
Kms =14569.3154 N/M
Rms = 20.4208 R mechanical
Efficiency = 0.3998 %
Sensitivity= 88.0361 dB @1W/1m
4.4net @ 26Hz is idea, sub likes 1500 ish daily, dont drop too far below tuning or expect it to bottom out. Excellent SQ from it in that enclosure, cross it at 60Hz and filter it 18dB/oct below tuning and it will please for a long time. Spiders are soft and prone to sag so dont mount firing up if ya can help it. 2" usable throw, high vas low qes means large port area is needed to keep vent mach in check. expect to use 72sq" of port area just to reach .05, but this means alot of air flow into the cabin to stir things up as well. excellent sub for those who can run it properly!
Heres a Vid to show they dont need much power, He's claiming under-powered but they are easily reaching Xmax. Box looks a lil too big though and he's more than likely tuned too high for them to really shine, these are true subs with better low end flat extension than a LMS Ultra 18... yes I went there, I have owned several of them so I'm allowed lol. Sold my LMS's kept my kove, that should tell ya something.
Audio_phill
Text 4 Help 276-685-1367
financethis
financethis
Kansas City, MO
financethis
