Last picture isn't mine, but its a birthsheet for the amp.
Works 100%, i'd say 8/10 condition wise "has scratches, but nothing deep, just some light scratches.... bottom has it the worst.
$225 + ship obo.... will take trades but not looking for anything in particular.
MADE IN THE USA !!!! YAY !!!!
Here are the specs.
* Efficient Class D Amplifier Design
* 2250 watts @ 1 ohm
* 1750 watts @ 2 ohm
* 800 watts @ 4 ohm
* THD at 1 Watt, 4 Ohm - 0.30%
* THD at Rated Power - 0.50%
* Signal-to-Noise Ratio, below rated power output - 100dB
* Frequency Response, at 1 Watt, 4 Ohm - 15Hz to 150Hz (+/-3dB)
* Frequency Response, at Rated Power, 4 Ohm - 20Hz to 250Hz (+/-3dB)
* Damping Factor at 20Hz, 4 Ohm - 400
* Crossover: Low Pass - 50Hz-150Hz, 24dB/Octave
* Crossover: Subsonic (High Pass) - 15Hz-40Hz, 24dB/Octave
* Bass Boost - 0 + 18dB
* Phase Control (Switchable) - 0 to 180*
* Input Sensitivity - 100mV to 2V
* (2V to 8V COMPATIBLE)
* Input Impedance - 10K-Ohm
* Line Output Impedance - 100 Ohm
* Peak Current consumption, at rated power into 1 Ohm - 175 Amperes
* Dimensions (W x H x L) - 10 5/8" x 2 7/16" x 18 3/4"
