16G speaker wire too small for a sub?
I love it when my wire GLOWS !
Anyways, the wire gauge you should use depends on the current and distance.
1200 watts @ 4 ohms = 12 gauge
1200 watts @ 2 ohms = 10 gauge
1200 watts @ 1 ohm = 8 gauge
http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SGPINS8&Product_Count=1
would this be the thing to use to get that 8 gauge wire into sub terminals and amps that might not accept 8 gauge speaker wire?
I know it might be a noob question, but I guess I am so it's a suitable question for me then.
Cause getting both wires of 12 gauge wire into sub terminals isnt easy itself when wiring down to a 1 ohm configuration, so I could imagine 8 gauge.
i've never really understood those. do they conduct more current then wire? because otherwise your connection is only as good as the bottleneck so you midas well just stick with wire
I always thought straight wire was best also, but I don't see how else to get 8 gauge in there without cutting down the wire, but then that is the same as getting those reducers.
Okay I am gonna get some 8 guage wires for my sub then thanks you guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
I use 12 ga for 1200 watt @ 3 feet @4 ohms,,,,18ga may not be able to handle the load and if I had 2 decide on 18 not being enough &12 not catching my car on fire,,,, I would just take the safe route and use more than maybe not enough
That's not true. If that were the case we'd be hearing reports of car fires constantly because no one would want to use fuses.
sound degredation in the case of speaker wire comes from voltage drop, and as Jmac eluded to, voltage drop is a function of both impedance/resistance AND distance. That 8 ga adapter might be thinner than 8 ga wire, but it's no more than an inch long. Any signal loss do to it would be negligible. Not only inaudible, possibly immeasurable.
BTW - http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Look, unless you don't give a crap about performance you should use 12g wire on just about any sub. Its not expensive and can have a significant impact on performance.
I really dont think he is going to use a mile or more of wire But My system is ran from Pioneer HU into 3 amps/ 2,400 watt 2 ch=1 sealed 15"xxx sealed/1000 watt memphis d-class=dual 1000 watt audiobaun 12" banpass/400 watt acoustic monobloc =5.25 drivers in the door and 10" r's in the rear deck. 4 monitors/10 disc cd changer
Basshead808
Basshead808
Big Island, HI
Basshead808
