15's in a 92 civic sedan ???
4 cubes sealed for both woofers together correct? that is still a huge box . most 15's now dont need a box that big. might be better off getting a new set of subs. a 2 piece box will be alot of work to remove and reinstall on a regular basis.
i dont plan on tracking often //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif kicker also said the smallest they could use is 1.75cf sealed each
and what about ported? Im measuring out my 99 coupe trunk right now and it seems to fit a box it cant be any higher than 15" to fit from the trunk. I might be able to pull 15.5" from the backseat but my bigass box for my current setup is in the way in the backseat. Tomorrow ill give it a try though. and also ill try 15" from the trunk. im testing out a 30Wx24Dx15H
just build a square bottom to the box that fits into the spare tire well and you can add a bit more space that way maybe you at least make the minimum per sub after displacement. depends on the shape of the trunk opening but just make it so it can still fit in and out. I can maybe draw it up if you dont quite understand, but I think this is doable so it still fits
This is how i got an 18 to fit in my 95 civic sedan.
i ordered 2 of these
Custom Enclosures MDFS15 - 15" Sealed Subwoofer Enclosures - Sonic Electronix
i figure 2 individuals are easier to remove not to mention the back seat opening and the trunk opening is only about 16 inches tall so these barely clear the opening lol
At least you can return those lol. If you built a box for them and they dont fit thats gona **** having to undo it to shorten it or something. Hope it fits though it said 1.9somethin cubes and i thought that was bigger than your max per sub. Let us know how it fits
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
Carnivorous18
