1500 watts daily driver?
My setup is pushing 1200w on stock electrics and I'm getting scared. 1500 would probably put you in some good head light dimming range and eat up your alternator or battery.
im worried about the sub not the stock electrical i have a red top and a 200 amp alt
"4. How 'conservative' are your RMS power specs?
If you want to run your woofer with no worry of frying your voicecoil or causing physical harm to your driver, the listed RMS specifications are a safe bet. If you are looking for maximum performance from each of our drivers, we would confidently advocate using ~500 and ~750 watts respectively, for our RL-i and RL-p Series drivers. When increasing the power input to your drivers, you will want to tailor down your enclosure volume slightly. It is also strongly urged that you contact us prior to using large amounts of power such that we may assist you in confirming that your enclosure is appropriate for the given power. "
That help?
XtrmAudioCncpts
XtrmAudioCncpts
Fairfax, Va
XtrmAudioCncpts
michigan born
    May 14, 2026
michigan born
    May 14, 2026
