1500 bd houston I think we have a problem
  • 4
Originally posted by chronic when I power this 1500bd rockford it make
a squealing noise.Any suggestions as to what the problem is?
What kind of squealing noise is it? Is it when the engine is running? Is it just straight powered on and nothing else on? Is it the head unit signal? A little more info here would help us to help you out better
thanks chris
i don't have a warranty for this bought off a guy
for $100 dollars, Can it be fix by me I know how to solder boards and electronics
wher can i pickup a power supply ,if i can fix it myself.
not sure man---- I don't think it would be that easy------
What I've seen happen in the past is the torriod (spelling) coil vibrates and causes that squealing noise. Find a silicon that has a high tolerance to heat and rub it onto the coil. It will dampen the vibration and hopefully stop the squealing.
Make sense?
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
341
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
573
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
9
928
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
834
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
chronic
chronic
ar
bean
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
