$150 To Spend, DCON The Best?
That depends if Im going to downgrade or upgrade. If Im downgrading, then $150 limit for a SQ 12 or pair of 8s off ~300w 4ohm. If Im upgrading, then a pair of 12s or single 15 off 1200w 2ohm, about $300-350 for sub/s and box. Still want SQ though.
I have roughly 5 cubes to work with (40L x 15H x 15D). Less is better though.
Well with upgrading subs means upgrading electrical
Not when running off the same amp. I never drop under 13.7 with my amp set to 1kw. So if I did sell it for another, I could probably run about 1500w off what I have. I plan to get a better starting battery as well.
Anyone know if the 1000C4 would be ok to run 2ohm bridged, since the eletrical is good?
don't quote me on this but i believe galacticmonkey said he ran his that way with no problems. I may be mixed up though.
Im thinking Ill keep the AQ order, and run it either off one channel, or 8ohm bridged if it cant handle 250-300 at 2ohm bridged.
run two //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif..sorry I was in the shop building a few boxes so I just got your pms.
Problem with that is I would then be paying out more money then I got for my SAs. Im thinking grab one for now and see how I like it, then go from there.
i thought the 1000C4 does 500 at 4 ohms?
I think its either going to be,
DCON 12 with my DSC480, 300w @ 4ohm
or
AQ 12 with the 1000C4, 250w @ 2 or 8ohm
It works out to be $80 more to get the 1000C4 and the AQ, but Id have a better amp, and be pushing my comps better. Or I could get the DCON and the 1000C4, but thats another $40.
And how does the IA 187 compair? Its $110 for the 12, and $120 for the 15. Its only D4 as well, so would only be able to give it 250w from the 1000C4 unless it can run 2ohm.
ctmaudi
ctmaudi
Akron, OH
09civic
