15 making a clicking noise?
  • 5
TJD15HC
Aight well i have one of my 15" HC's in a 4.5 cubic foot box tuned to 36hz, hooked up to a 300 watt rms power amp rated at 16ohm lol Its running at 2 right now, and seems to be fine.
Anyways. When i turn it up pretty good, ( by the way is running through a crossover so its just lowpass fq) it seems to make a like clicking when the bass hits sometimes. It doesn't look like its bottoming out? Maybe it is? Im not running a sub filter or anything. And its prolly not seeing anymore than 600 watts.
Any ideas?
Tim
Its not a loud tapping or anyhting just a light click.'
Could it just be distorting cause im underpowering it and giving it too much volume?
Meh i dunno its not a car amp, home strereo power amp for a sub.
600 watts is too much for it to be underpowered. so it has to be something else. is the gain or the bass boost up all the way? I'm not sure, but that could be the problem.
845
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
TJD15HC
TJD15HC
Cambridge Ontario
TJD15HC
    May 18, 2024
    May 16, 2024
