13.4 low voltage at idle?
99grandprixGT
now got an 04 grand prix
my dad called me and told me his battery light on the dash lite up. i told him to check the voltage with a DMM at idle he was at 13.4. now i think that is really low at idle with no accessories on. it dose not even have a CD player. you guys think the alt is going out? the battery is resting at 12.75 with car off i think its still good.
Bat sounds fine. Alt doesnt sound too bad either. I know that with my stock alt the only time I would sit at 14.4 was in the morning when i first started my car. After that it would be 13.5-13.8ish.
clean the cables, make sure they are on nice and tight and re-check
all right ill give that a try.
ya i just dont want it to be to late and end up draining the battery all the way down.
13.4 isn't low low, but it isn't working properly.
Check all the connections real good.
ya im going to do that in the morning. thanks for the suggestions guys.
same here! i've seen mine as high as 14.8 in the morning when the car first starts up but then by the time i get to work(a 10-12 minute drive) it's down in the mid to high 13's.
i just wish when my engine was off that my voltage would sit a bit higher.
ill have to check that out ill start it up now after its been sitting for 12 hrs and see what its at. but i mean the only reason i think something is wrong is becaue the battery light came on while driving. so dosnt that mean that the voltage reached an unsafe point.?
99grandprixGT
99grandprixGT
home
regal8r
