bumpin buick
Science is everything
just curious in that video why is the clock stopped? Do they do something different that im not aware of down there?
AB 1000.1 @ 1.33 per sideSo that's basically 2 500.1s @ 1.3 vs 2 3500s at what ohm?
Did you wire em lower to gain or what?
I got mine from a local specialty store :Hey sundown where do you get those threaded brass rods from home depot, lowes?
Electrical had nothing to do w/ the protection -- it protected at probably around 100 watts (125 dB). The protect circuit simply would not allow it to run that load whatsoever. Two huge 120+ pound batteries were about 12 inches of cable away from the amp as well for that matter //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifim pretty sure his drivers door was pretty phucked already and the hatch was repaired before also.that ab 1000.1 could handle those loads if he had better electrical i do believe.i think he still has cca 1/0 cable run from the front.i keep tellin him to get rid of it....
and who are you?oh yea hes happy...they're loud and i knw he also loves the wow factor.
how about, or why not just run the wire direct through a small hole and caulk it?Wooden distribution blocks add the dBeez *laughs*
In all seriousness if I had the supplies I'd of liked to have seen brass threaded rod speaker termination like I use on my boxes - but I didn't have the supplies or the time :
I gained 0.3 dB doing that vs. taking them out of the port.
