12v through MDF
He has his car wired with Belva 0g (real 4g). The wire I plan on using inside the box is 0g knu klmx I have lying around which is a lot thicker. I plan on making sure everything is secured and tight. Battery is in the trunk and fuse is 150a
Oh my Bad I thought you meant speaker leads ! No I wouldnt do that cuz fuses take a while to blow and in that time your studs could heat up and cause a fire ! You have a fire extinguser ? Lol I got one after first amp burned up. So much smoke in the cab I barly got pulled over and batterys un hooked before I had a bigger problem !
sciontistbb
sciontistbb
In the garage
ChaseinBass
