120A fuse for SAE-1200?
I'm gonna have to say, you'd want at least a 150 amp fuse at the battery...//content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gif
If you use a 120 amp fuse at the battery, and your amp needs 150...what do you think is going to happen to that 120 at the battery? POP! //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
--edit--
And what zero gauge wire did you buy that came with a 120 amp fuse? I don't think I've ever seen that before. Are you sure it's not like 4 gauge or something?
--edit--
Well thats kinda what I figured what would happen. Just checkin I guess.
Idk what kind it is. I bought if from a guy off of here, he said he thought it was Stinger. Its not a regular fuse either though, its called a "car audio breaker" and it came with it. I think Im just going to go buy a different fuse breaker.
Well if it's a breaker, then go for it! You only have to reset the breaker right? Fuse holders aren't cheap (unless you get 'em online, or even here!). Try using the breaker and if it trips too much, then get the ANL fuse holder.
muddin wolvy
muddin wolvy
Henderson, KY
muddin wolvy
