12" Fi BTL N3 enclosure NEED HELP.
  • 4
KZnova
NJ 07036
So what we have:
Golf 4
12" Fi BTL N3 dual 1.4 coils (0.7 wired)
MB Quart Discus 2000.1 (true rms, same board as on AQ2200)
65Ah battery (noname, but soon will change for Stinger 1700)
0/1 Ga from (only + connected directly to battery)
Alpine 9886 HU
What we need:
Maximum dB output that we can take from it. Im thinking about 1.7 cuft clean vol. and four 110mm diameter tube ports tuned 50-53 Hz. But they are too long, what do you thing maybe it will be enough to use three tubes? Also what do you thing about clean vol. that i choose for box? And maybe somebody know Golf 4 resonance?
Thanks.
P.S. Now sub is playing in music box, you can watch it on YouTube:
With just 2kw on tap, you can go bigger on the box. I wouldn't do 1.7ft^3 unless you're running a good 5kw to that sub. Do 2.5ft^3 with the same 50hz tuning.
ok man, i think i will try something about 2-2.2 cuft
What's the resonance frequency of the vehicle?
that the problem, i dont know and i dont have termlab //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif, but it should be about 51-55 hz
Unless we're talking about pairing them with amps of those ratings I wouldn't call that honest, but probably consistent with what the vast...
  • Locked
Negative 1aespinoza . The spider landing is to big on the newer 12 spokes like you posted . I need the old school 12 spoke. Nobody here has...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
KZnova
KZnova
NJ 07036
Bettr n' Revrse
audiobaun
    May 19, 2024
    May 19, 2024
