12" Fi BTL N3 enclosure NEED HELP.
KZnova
So what we have:
Golf 4
12" Fi BTL N3 dual 1.4 coils (0.7 wired)
MB Quart Discus 2000.1 (true rms, same board as on AQ2200)
65Ah battery (noname, but soon will change for Stinger 1700)
0/1 Ga from (only + connected directly to battery)
Alpine 9886 HU
What we need:
Maximum dB output that we can take from it. Im thinking about 1.7 cuft clean vol. and four 110mm diameter tube ports tuned 50-53 Hz. But they are too long, what do you thing maybe it will be enough to use three tubes? Also what do you thing about clean vol. that i choose for box? And maybe somebody know Golf 4 resonance?
Thanks.
P.S. Now sub is playing in music box, you can watch it on YouTube:
With just 2kw on tap, you can go bigger on the box. I wouldn't do 1.7ft^3 unless you're running a good 5kw to that sub. Do 2.5ft^3 with the same 50hz tuning.
ok man, i think i will try something about 2-2.2 cuft
What's the resonance frequency of the vehicle?
that the problem, i dont know and i dont have termlab //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif, but it should be about 51-55 hz
KZnova
KZnova
NJ 07036
Bettr n' Revrse
