10w7?? or RE SE 12??
even though the 10w7 has a smaller cone...it has a longer xmax than the se12 becuz the se12 has a larger cone but a smaller stroke...but when u compare the two.......they displace almost the same amount of air...the 10w7 edged out the se12 by a very very small margin..its so small your not going to notice a difference...so being that they move the smae amount of air give or take...its all about which one is more sq oriented
80
i'm not disconting the w7. the se is more spl oriented then the w7. i said the w7 would have better sq, but not much.
Buy the w7.. you also get that extra wow factor when you show your friends //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Although for the extra $$ spent for the W7 there wouldn't be hardly enough difference to satisfy me
So why would you recommend it to this guy, in this installation?
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Because I don't have 350$ to spend on a sub, so I would more then likely go for a cheaper sub. Notice how I said staisfy me? He asked which sub would get louder, if I am correct.. I believe that would be the W7. and yes.. I would love to have the pleasure of owning a W7 to show all of my friends.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so i guess if i learned anything from the hard ons as of late w7//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You said $350 was your budget?
$139.99+Shipping
12 Inch 2005 ||Alpine Type R||
RMS Power Range : 50-500 Watts
Peak Power Handling: 1500 Watts
Impedance: Dual 2 Ohm
12" component subwoofer
Kevlar-reinforced pulp cone
Cast aluminum frame with perimeter venting
Dual 2-ohm voice coils
Low Frequency response: 24 Hz
High Frequency Response: 500 Hz
Sensitivity: 87 dB
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2530
You might even beable to find a 12' cheaper on ebay.
$199.00+Shipping
15 Inch 2005 ||Alpine Type R||
RMS Power Range : 75-750 Watts
Peak Power Handling: 2000 Watts
15" component subwoofer
Low Frequency response: 22 Hz
High Frequency Response: 1000 Hz
Sensitivity: 89 dB
http://www.ikesound.com/product-product_id/3566
*NOTE* The Type R's are heavenly underrated.. you should have no prob giving them about 200 more watts.
$319.00+Shipping
12 Inch 2005 Alpine Type X
Frequency Response: 23Hz ? 200Hz
Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp Cone
Ultra High Excursion Multi-Roll Injection Moulded Santopreneᆴ
Mirrored Progressive with Perimeter Venting
Compound Radius Curve
Cast Aluminum Internal Stacking, Vented Leg/Spider Landing with HTP
Extended Dual Flare Pole Vent
High Strength Brass Voice Coil Bobbin
Machined Insert Blocks with Housing, VC Connection Jumper System
Copper Shorting Sleeves with Thermal Coupling Plate
Designed and Engineered in the USA
Power Handling Capacity (Peak) : 3000W
Power Handling Capacity (RMS) : 1000W
Diaphragm Material : Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp
Magnetic Weight : 130oz.
Mounting Depth (top mount) : 218 mm (8.6")
Mounting Diameter (top mount) : 231 mm (9.1")
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.75 ? 2.0 cu. ft.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1855
If you have any more questions.. let me know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hey...thanks every one for the interesting responses...reasoni dont got wit an aa or a type r 15 is my space restircition....i have a 15 ae...if anythign i would have gone wit that ...im im limited to a 10 or 12....reason whyi chose the 10w7 is cause the 12w7 wieghs like 45 pounds and my car is alrdy slowed down from my amps and the custom installation they got.. and the 12w7 locally goes for 450 straight....
i heard the type r's were real good for the money ...butt isnt the w7 like a super sub....so shouldnt it have some type of advantage??? i would think so...but im not sure....my budget is around 300-400
dustin that apline type x u showed me wit shipping n every thing woudl be almost the same as the 10w7 and i havnt heard too much about that sub.....anyone wit experience wit that sub/???
im still stuck!
i chose the Se over the type R.... i was very pleased with the choice...
as for the w7 vs the Se i think overall the w7 has the edge but the cost far outweighs the benefit.... I would go with the SE... it is an excellent driver for SQ and it gets **** loud... I had 2 12" se's in a sealed 1.25 each box, and they were banging...
just my opinion
i would go with the rl-p over the se or w7, and yes i have heard a w7. got a chance to try one out in my car and i was glad i did because imo it didn't live up to it's billing. it was a nice sub, don't get me wrong, just not worth forking over the cash for it. an rl-p will get loud and have amazing sq.
spicmonster
spicmonster
New York CITY
dustinr
