1000+ Watt Amplifiers
EARTHQUAKE PH-D3 "THE ROCK" Mono Block 5000 Watt Competition SPL Amplifier!
~5000 Watts Maximum Power
~3000 Watts x 1 into 1 ohm
~2600 Watts x 1 into 2 ohm
~1300 Watts x 1 into 4 ohm
newbie here just wanting to know what amp u guys would suggest getting around $250 for mtx 6000 subs.
A while ago I bought two mtx 6000s and powered them by the mtx 421D and that easily powered them, until they blew. They are rated at 250rms i believe...So any fair amp can power that. Check out ebay for some 421ds cheap.
Memphis Audio
16-MC1000D, 1100 @ 1 ohm
Memphis Belle
75 x 4 and 1100 @ 1 ohm
16-MC1300D //content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif
EARTHQUAKE PH-D3 "THE ROCK" Mono Block 5000 Watt Competition SPL Amplifier! ~5000 Watts Maximum Power
I was waiting for someone to mention earthquake amps...
They also have PHD-5 which puts out around 10,000 watts but it's a 5 grand amp.
Lol you obvisously do not know anything about the PHD-5. It does not put out 10k, it puts out if at best 5k. Its a modded D-3 as stated, and its no wheres 5grand.
Got mine for 750$, and it retails for maybe 1k if that.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
800
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Gauntlet
bulletproof
Gauntlet
Cleveland, Ohio
Phlipbak
