10 Sa-10s D2s what is the final ohm load ?
about 500-600 a piece I have 4 now feeding them a little over 800 a piece and they are fine but thats a alot of power for 10 woofers which mean lots of $$$
Looks like 1.6ohm is going to be your best bet. I'd strap a pair of 2-3kw amps and be pretty happy. It'd be best for you to find out the actual imp of the coils so you'll know where you'll really be sitting.
I will pull one out of my box and see wat it says
Will running new and used subs together affect them ? The ones i have are not fully broken in but they will be by the time i get the new ones
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Varinabassing
Varinabassing
Richmond,Va
Varinabassing
    May 31, 2024
    May 24, 2024
