Can not remove headunit...
david522
I just can't figure out how to remove the headunit. Have tried wedging out with 2 screw drivers but to no avail. I want to remove it so I can access the aux at the back.
I would ideally like to attach an image but this forum doesn't allow it...
http ://iforce.co.nz/i/wxllrr0c.lin.jpg
Have spaced the url out if anyone is bothered.
Thanks.
There should be a slot on each side of the head unit after you take off the trim piece. You need a long thin piece of metal that can slide in between those holes all the way to the back. I found 2 long metal sticks by taking apart a file folder that had hooks on it. Just slide them in the holes and pull the radio at the same time. It should come out if you wiggle it enough.
david522
david522
New Zealand
AJM511
