'10 haz0388 Eclipse Build
what year eclipse is that?sorry if i missed it,also what kind of numbers have you done previously and what was the setup like.i am in the process of helping a friend with an '03 eclipse
it is an 03 eclipse. last year with 2 aq hdc315s and a stetsom 4k2d i pulled a 150.4 db sealed up...legal db drag score. in usaci sb3 i did a 150.7. and in outlaw i burped a 152 even. now the year previously i did a 149.4 legal with 2 atomic apx10s and an atomic 5000.1.
finally got the amp side done.
im not either. the one amp is crooked for sure joe. i think ima just take them both off. add a sheet of wood on top and replace the wood there so its all one layer and have them both like the amp on the right. that way they are the same. i dont like how that looks.
alright finally got time to work on stuff. changing out both rear panels i made. going to just the 4 channel amp and also changing the other side to fit the 3 C&Ds without blocking sub direction or air flow. also in the meantime i changed the headliner from tan to black and got one door panel done.
parts of the door panel looks like its sagging but its all just the shape and curves of the panel. one part started to sag by the last speaker due to the drilling of the speaker in the baffle. will just have to remove the speaker and go back in with adhesive on that spot.
hazardous0388
hazardous0388
Springfield, MO
hazardous0388
