'10 haz0388 Eclipse Build
are yall actually going to care about points this year? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No, just mentioned it being a 1x as the 2x/3x events won't let you use an iPod or sit in the vehicle if it's over a 140. I'm all about demo's and hanging out, points make no diff to me...
hmmm the only sanction i know about being outside of vehicle is meca and thats any class over 145db i believe. but every sanction is defiantly trying to promote more safe practices. either way i pull my deck out of the car so won't hurt me at all.
how you been joker?
how you been joker?
Do you pull daddy's dick out so it will not hurt you too.... I luv's you Dusty
no i usually let you keep it in.
and i recieved a sheet of wood yesterday from a friend for free. yert it started snowing again so once again...i cant start on the floor in the back seat area unfortunatly. will try to do some tomorrow tho.
the only thing thats holding he big build back is the false floor. the floor will house the enclosure for the 8 MB Quarts, 1 battery, both monoblock amps, and allow the wiring to get cleaned up. once thats all done...the sub box will just go in the trunk.
Go pay some bums to hold a tarp over your car so you will stay dry bish
how you been joker?
good. just working alot of ot to do my new setup
alright did some work today. the actual main floor board is in and mounted. on one side i started the gap filling process. this is a two step process...adding length to the main floorboard and then adding a strip going from front to back to clean the gap up which will also be the piece that will be removed if rewiring will need to be done. now once both sides are done...there will be a front trim piece over the WHOLE floor between the seats and the floor,thus making the monoblock amplifiers look receased into the floor. should turn out nice when it is completed.
hazardous0388
hazardous0388
Springfield, MO
hazardous0388
