1 Ohm Stereo Amps ----Which ones----PLeez help quick!!
DJ Jester
Can someone give me the names of any 1 Ohm Stereo stable amps?
I'm looking for one to run some speakers up front, but on each channel I will have it running two 4 Ohm speakers and one 8 Ohm for a total impedence of 1.6 Ohms.
I'm afraid if I try this on one of the amps that I have that it will fry it in a matter on minutes.
I'm looking for about 75 watts per speaker, maybe a little less, and I'm hoping to spend less than $150 for the amp, used off of Ebay or some such.
Please help quickly as I need to make this purchase by tomorrow.
Thanks for any help you are able to offer!
Jester
PS--I just thought about it and had a brainstorm. Can't I wire the two 4 Ohm speakers in series and then run that parallel with the 8 Ohm speaker for a total of 4 Ohm load on the amp? Is this possible? If it is, can someone direct me to a diagram or tell me how to do it?
Thanks again!
kicker zr 360
spec are: 90 x 2 at 4ohms
180 x 2 at 2ohm
200 x 2 at 1ohm
360 x 1 at 4ohm (mono)
400 x 1 at 2.66 (mono)
400 x 1 at 2ohm (mono)
these amp have been bench tested at 550 watts into a 4ohm mono load
kicker zr 600
spec are: 150 x 2 at 4ohm
300 x 2 at 2ohm
275 x 2 at 1ohm
600 x 1 at 4ohm (mono)
600 x 1 at 2.66 (mono)
550 x 1 at 2ohm (mono)
these amps have bench tested at 700 + watts into a 4ohm mono load
wire your two 4ohm speakers in series for a 8 ohm load
then wire your 8 ohm speaker in parallel with your 2 speakers
that are wired at an 8 ohm load for a 4 ohm load to your amp
DJ Jester
DJ Jester
New Orleans
DJ Jester
