- Thread Starter
- #16
thanks man,It can and will hurt. The cap is useless, don't bother installing it. Thats just my opinion, it wont help at all. And no one answered you so here goes, you're correct the fuse is there to protect the wire so you fuse to the rating of the wire. 0 gauge is usually fused at 300 or 350 amps. Your not going to be pushing the limit of that wire so i would just go with 300 amp fuses. Good luck!
so when you say use 300amp fuses that is everywhere 1/0 wire is...So basically everywhere I need a fuse...Cool thanks...
Now on the cap, it will hurt my system??? Sorry but i am lost here, I bought it because I was told that if your amps don't get all the power they need, they distort and clip and that I was told is no bueno...So I was told to put a cap in line so that if my amps demanded more then my alt could provide them then the cap would add the additional power required to do the job correctly???
Is that not correct, I believe you, I just like to know why...
Oh shit, that means I have to find a new power/ground dblock because the one I have is midi fused and midi fuses only go up to 175amps...
This shit is way more complex then I ever imagined, I just thought, buy stuff install it and listen...LOL...****,****,****,
