Hey all,name is jeff and I am 37 and live in Las Vegas, Nv...
Just getting into this car audio world and this is what I have purchased/in process of purchasing so far;I am going to install the HU, 6X9's and 6.5"'s,sound deaden the interior,change out the big 3 and install the 170amp alt all myself, and then have a professional installer wire up the sub box,charge up the cap,set up the amps and tune the system with my imprint setup...Should be a nice little system, nothing like alot of you guys have, but hey, its a start..
Alpine ida-x100 hu
Alpine kca-422i full speed ipod cable
Alpine kce-300BT bluetooth module
Alpine kca-sc100 sirius module
Alpine pxa-h100 imprint module
Alpine ktx-h100 imprint sound mngr kit
Alpine spr-69c type R 2-way 6X9's
Alpine spr-17s type R 6.5" separates
Alpine mrp-f550 4 ch 90X4@4ohms@.08%
Alpine mrp-m850 mono amp @ 800X1@2ohms
Alpine swr-1222d type R dual 2ohm sub
geek squad 6' gold plated USB cable
stinger rkx4 expert roadkill universal kit
stinger rkxlic expert roadkill licence plate kit
stinger rkcp12 expert roadkill floor pad
stinger rkxdk expert roadkill 2 door kit for inside door
stinger rkxdk expert roadkill 2 door kit for outer door
stinger rkxtk expert roadkill trunk kit
stinger spi-4320 pro 3 20' 4 channel RCA
stinger spi-2320 pro 3 20' 2 channel RCA
stinger shc5015 15 farad hybrid cap
stinger shd870 midi fused pwr/grnd D/B
stinger spv35 honda dry cell batt
stinger spt53302 batt term(1-1/0,1-4,2-8)
stinger spt53102 batt term(1-1/0,1-4,2-8)
stinger shw514bc 80' 14g twisted speaker wire
stinger shw44y 14g twisted wire Y bootys for speaker wire into amp
stinger shw18c 15' of 8g clear sub/box wire -
stinger shw18b 8' of 8g blue sub/box wire +
stinger shw14b 10' of 4g blue amp wire+ from dblock to amps
stinger shw14c 10' of 4g clear amp wire- from dblock to amps
stinger spt522 4g to 8g reducer for 4ch amp connection +
stinger spt522 4g to 8g reducer for 4ch amp connection -
wire for big 3
stinger shw14b 6' of 4g blue alternator power to batt wire
stinger shw14c 3' of 4awg clear batt to chassis and engine to chassis grounds
stinger sht24 4g ring terminal for alt post,
stinger sht24 4g ring terminal for chassis to batt ground,chassis side
stinger sht24 4g ring terminal for chassis to engine ground,engine side
stinger sht24 4g ring terminal for chassis to engine ground,chassis side
I still need;
a sub box(thinking subzone z series)
ground mounting post,
firewall grommet,
various connectors,
possible 1/0 to 4g reducers
???possible inline fuse holder for alt to batt run???
fuses,
remote wire,
power wire from batt to cap,
ground wire from ground post to dblock,
170amp Load Boss alternator...
And I am done, I think??? Have I missed anything??? Like I said new to car audio, done lots of research but not sure if I missed anything???
here is where I am stumped, I am not sure what size power wire from batt to cap??? I have seen the stinger 1/0 and 4g amp wiring kits and I am looking at these kits;
1/0 kits
shk201=$120.00
swkh0 = $99.00
4g kits
swkh4=$62.00
shk241=$58.00
but not sure which size and which one would be best for me as I already have most of what I need to install this beast... I think??? it seems that all I need to know now is;
answer:
batt inline fuse size (18" from batt terminal)
answer:
what sized fuses for dblock right before amps
answer:
????????? fuse/fuse holder for alt. to batt wire ?????
I have heard
"use a fuse between this run" and I have heard "do not use a fuse for this run"...Well, whats the correct answer???...LOL...
answer:
information needed for answering above questions:
both amps total are 1160watts RMS and 135amps & total run of approx 12-14'
2X30 & 3X25 amp fuses...4 ch will be running in 4 ohm and mono will be running 2ohm load...thats right at the Max for watts and amps on 4g but this setup will not change,so would using 4g be safe or just buck up the extra $$$ and just go 1/0???
I also have an issue with what to do with the power wire from the alt to the batt for changing the big 3...My car is a 1999 honda civic ex that still has the stock wheels,springs and exhaust so no I am not fast and the furious...LOL...)
If anyone has changed out the alt power wire on a 1999 honda civic, please speak the hell up...Thank you in advance...//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
thanks for any help and hope to become a contributing member of the forums...It'll be a while but it'll happen...//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Alpine ida-x100 hu
wire for big 3
I still need;
firewall grommet,
various connectors,
fuses,
remote wire,
1/0 kits
shk201=$120.00
swkh0 = $99.00
4g kits
swkh4=$62.00
shk241=$58.00
answer:
answer:
answer:
I have heard
answer:
