james33440
Which would be better to use with my current all 4-gauge power and ground cables and MMATS D300HC amp - one batcap 400 series or 2 1-farad capacitors with bussbars?
ya just look at em....it should tell you it isn't a good ideaOriginally posted by HectorZ how ?
look at the specs on this bad fella
http://www.batcap.net/Model400.html
noA question:
if I rewound my amp with my, currently, 600 watt setup, to say 180 ampers...
would I still "need" one of these capacitor things ?
If I were you, for now I'd do neither. I don't think you'll have a problem at all. If you do, then look into what you need to do to fix it.Originally posted by james33440 Which would be better to use with my current all 4-gauge power and ground cables and MMATS D300HC amp - one batcap 400 series or 2 1-farad capacitors with bussbars?
