1.5" slot port too narrow?
  • 4
steelr
25
Indiana
I am building a box for my Adire Tempest. Ported enclosure 2.5 cubic foot tuned to 25hz. I am looking to slot port the enclosure with a 1.5"X15" port 32" long. Is the 1.5" opening too narrow? I am new to slot porting and needing any help i can get.
Ok I will increase the port size to 2.5" or 3". Should the port be on the same side of the box as the woofer? Example is the woofer is facing forward and I was planning on having the slot on the front of the box also. Is this ok or should I port it out the side? This is a trunk install and the seat doesnt fold down.
If it is ok to put the sub and port on the same wall, would it be better to face the rear of the car so it can "breathe" ?
747
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
906
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
615
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
773
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
steelr
steelr
Indiana
steelr
